Outbound number identification - CME 7.1
Answered Question
Aug 19th, 2010
I have and issue that the outbound calling info is incorrect from the 2811 CME box. We currently have a PRI terminated into this box and would like to change the number being sent/displayed on outbound calls to external cell phones/devices. Any idea how I do this?
Correct Answer by philip.e.denton about 6 years 6 months ago
If using translation rules to mask everyone to the same number:
voice translation-rule 1
rule 1 /.*/ /3305551212/
voice translation-profile CALLERID
translate calling 1
dial-peer voice 10 pots
translation-profile outgoing CALLERID
destination-pattern 81[2-9].........
port 1/0/0:23
forward-digits 11
Correct Answer by Justin Brenton about 6 years 6 months ago
If you want to have the same number for all outgoing calls then you can add "isdn calling-number xxx-xxx-xxxx" to your serial interface as shown below.  If you want everyone's DID to go out as there own number then you will need to create translation's on your gateway to do acheive this.
interface Serial6/0:23
no ip address
no logging event link-status
isdn switch-type primary-ni
isdn incoming-voice voice
no cdp enable
HTH, Please rate if so.
Justin
Overall Rating: 5 (3 ratings)
Correct Answer
Justin Brenton Thu, 08/19/2010 - 10:52
no ip address
no cdp enable
Justin
Correct Answer
philip.e.denton Thu, 08/19/2010 - 11:27
translate calling 1
port 1/0/0:23
forward-digits 11
