Unity Connection e-mail notification
Answered Question
Aug 19th, 2010
I have Unity Connection e-mail notification configured with Cisco PCA link embedded. However, the URL comes with the name of the CUC. Is there a way to change the name by the IP address instead?
Correct Answer by Justin Brenton about 6 years 6 months ago
Sorry, try this
System Settings -> Advanced ->Connection Administration-> Host Name/Address for Link to Cisco PCA in Notification Messages
http:///ciscopca
Justin
Overall Rating: 5 (2 ratings)
Justin Brenton Thu, 08/19/2010 - 10:44
If you login to Unity Connection and goto System Settings->SMTP Configuration->Smart Host
Do you have the hostname or IP address listed here?
Justin
mnkojima Thu, 08/19/2010 - 12:42
Hi Justin
In the field smart host I have the IP address of my mail server which I am relaying the mail notifications.
My problem is that when the user receives by e-mail the message of new voice mail, there is an URL point to cisco PCA in the e-mail body, something like:
https:///ciscopca
I need to replace the CUC name by its IP address...
Thank you
Marcos
Justin Brenton Thu, 08/19/2010 - 12:49
Ahh ok gotcha
You need to set up the URL in the SA. Go the System | Configuration |  Settings screen and look for Cisco Personal Communications Assistant  (PCA) Internet Address.
Make sure to use http://  so it shows up as a clickable link.  http:///ciscopca
Justin
mnkojima Thu, 08/19/2010 - 14:02
I haven't found the path... Is it for Unity Connection 7.x?
Correct Answer
Justin Brenton Thu, 08/19/2010 - 14:29
Sorry, try this
http:///ciscopca
Justin
