Clarification needed on upgrading IOS image on stack switches (3750)
Aug 19th, 2010
I am upgrading new IOS image on a stack switches of 9 (3750G-48TS) for enabling faeture of SSH as it is currently lacking SSH login feature. I came across through cisco documentation that I can upgrade the new IOS image on all 9 switchs of a stack with a single command. Below is the link for your reference:
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_configuration_example09186a00804799d7.shtml#cfbin1
Right now all switches have the new IOS k9 image copied. Attached file you will find the switch details with current and new IOS image for your reference:
I have a doubt like, if i proceed with the above cisco documentation on step 4 as "boot system switch all flash:/
c3750-advipservicesk9-mz.122-52-SE.bin
Switch(config)#exit
Switch#write memory
will it boot with the new IOS image on all member switches or on only master switch will reboot with the new IOS.
Kindly share the expereinces with a similar situation realted to the stack 3750G-48TS switches.
Much appreciating your response
Mohammed
Asad Raza Thu, 08/19/2010 - 11:22
If you reload the master then whole stack will reload and boot up with the new image. You can also try reloading one member switch at a time by using  'reload slot stack-member-number'
mhabeeb_ahmed Thu, 08/19/2010 - 12:38
Thanks for your reply.
I'll try this as well for an alternative.
Mohammed
Leo Laohoo Thu, 08/19/2010 - 16:16
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Sure you can.  But it's a heart-stopping experience when the switch of this huge stack because it will "pause".  The command is "arch download-sw /dest 1 /dest 2 /dest 3" ...
I never use this command unless I have more than one IOS in a switch.  The 3750G-12S, for example, does not have enough flash space for two full IOS.
mhabeeb_ahmed Thu, 08/19/2010 - 17:21
I tried as per cisco documentation but it is failing
on member switches. Can anyone quickly update me on this becuase my downtime of
changemanagment is of 1 hr from now.
below is the error I am getting:
s1-401(config)#boot system switch all c3750-ipbasek9-mz.122-52.SE.bin
%Command to set boot system switch all c3750-ipbasek9-mz.122-52.SE.bin on switch=2 failed
%Command to set boot system switch all c3750-ipbasek9-mz.122-52.SE.bin on switch=3 failed
%Command to set boot system switch all c3750-ipbasek9-mz.122-52.SE.bin on switch=4 failed
%Command to set boot system switch all c3750-ipbasek9-mz.122-52.SE.bin on switch=5 failed
%Command to set boot system switch all c3750-ipbasek9-mz.122-52.SE.bin on switch=6 failed
%Command to set boot system switch all c3750-ipbasek9-mz.122-52.SE.bin on switch=7 failed
%Command to set boot system switch all c3750-ipbasek9-mz.122-52.SE.bin on switch=8 failed
%Command to set boot system switch all c3750-ipbasek9-mz.122-52.SE.bin on switch=9 failed
what to do next from here?
mhabeeb_ahmed Thu, 08/19/2010 - 17:26
I even tried individually but still the result is same:
hqans1-401(config)#boot system switch 2 c3750-ipbasek9-mz.122-52.SE.bin
%Command to set boot system switch 2 c3750-ipbasek9-mz.122-52.SE.bin on switch=2 failed
Leo Laohoo Thu, 08/19/2010 - 17:29
  • Hall of Fame,
    2017 LAN, Wireless
How many IOS do you have in your switch?  If you have only one, then disregard this.
mhabeeb_ahmed Thu, 08/19/2010 - 17:33
We have two IOS image on the switches as depicted below:
s1-401#sh flash
Directory of flash:/
    2  -rwx       61573   Dec 5 2009 11:54:43 -08:00  hqans1config
    3  -rwx       60521  Aug 19 2010 17:16:05 -07:00  config.text
    4  -rwx        1224  Jul 16 2010 16:58:22 -07:00  vlan.dat
    5  -rwx       21528  Aug 19 2010 17:16:06 -07:00  multiple-fs
    6  drwx         192  Feb 28 1993 16:09:15 -08:00  c3750-ipbase-mz.122-25.SEE3
  459  -rwx          27  Aug 19 2010 17:16:05 -07:00  private-config.text
  460  -rwx    11110304  Jul 13 2010 10:19:50 -07:00  c3750-ipbasek9-mz.122-52.SE
  461  -rwx    11110304  Jul 13 2010 10:59:40 -07:00  flash3
32514048 bytes total (1355264 bytes free)
s1-401#sh flash2
Directory of flash2:/
    2  -rwx       60521  Aug 19 2010 17:16:08 -07:00  config.text
    3  -rwx          27  Aug 19 2010 17:16:08 -07:00  private-config.text
    5  -rwx       21528  Feb 28 1993 16:56:57 -08:00  multiple-fs
    6  drwx         192  Feb 28 1993 16:09:40 -08:00  c3750-ipbase-mz.122-25.SEE3
  459  -rwx    11110304  Jul 13 2010 10:27:43 -07:00  c3750-ipbasek9-mz.122-52.SE
32514048 bytes total (12527616 bytes free)
s1-401#sh flash3
Directory of flash3:/
    5  drwx         192  Feb 28 1993 16:08:59 -08:00  c3750-ipbase-mz.122-25.SEE3
  458  -rwx       21528  Feb 28 1993 16:56:57 -08:00  multiple-fs
  459  -rwx    11110304  Jul 13 2010 11:06:02 -07:00  c3750-ipbasek9-mz.122-52.SE
mhabeeb_ahmed Thu, 08/19/2010 - 17:50
anyone can let me know what next to be done with the other stack switches (2-9)??/
Leo Laohoo Thu, 08/19/2010 - 17:55
  • Hall of Fame,
    2017 LAN, Wireless
Do you still need 12.2(25)SEE3?  If not, delete the file and subdirectory using the command "delete /f /r flash1:c3750-ipbase-mz.122-25.SEE3" and so on.
mhabeeb_ahmed Thu, 08/19/2010 - 18:25
I see some problem here
I reload the stack ..........
hqans1-401#sh switch deta
                                               Current
Switch#  Role      Mac Address     Priority     State
1       Member    001c.b0aa.d000     15        Ready
*2       Master    001c.0fe2.5400     1         Ready
3       Member    001c.b135.4600     1         Ready
4       Member    001c.5721.df80     1         Ready
5       Member    0000.0000.0000     0         Provisioned
6       Member    001c.0fe2.5d80     1         Ready
7       Member    001c.5721.de00     1         Ready
8       Member    001c.0fe2.6480     1         Ready
9       Member    001c.b149.7400     1         Ready
         Stack Port Status             Neighbors
Switch#  Port 1     Port 2           Port 1   Port 2
  1        Ok         Ok                2        9
  2        Ok         Ok                3        1
  3        Ok         Ok                4        2
  4       Down        Ok              None       3
  6        Ok        Down               7      None
  7        Ok         Ok                8        6
  8        Ok         Ok                9        7
  9        Ok         Ok                1        8
Leo Laohoo Thu, 08/19/2010 - 18:41
  • Hall of Fame,
    2017 LAN, Wireless
Looks like you need someone to eyeball the switch.
Leo Laohoo Thu, 08/19/2010 - 20:01
  • Hall of Fame,
    2017 LAN, Wireless
... OR maybe it may just take a little while because you are upgrading from 12.2(25) to 12.2(52) which requires the new IOS to upgrade the Bootstrap and require to boot TWICE.
mhabeeb_ahmed Thu, 08/19/2010 - 21:12
might be i have to check. As of now i have rollback on the old ios image and the switches are running normal. I need to figure it out tommorow morning.
One way in my mind is that I can break the stack and give the boot variable on individual 9 switches. But I think there is also a way that we can upgrade
IOS and can have the boot variable on the stack switches without breaking stack.
Any help would be appreciated in this regard.
regards,
Mohammed
Related Content
