Problem to change IP address CallManager 6.0
Answered Question
Aug 19th, 2010
  • " /> Participante em Destaque,
    Prêmio"Escolha dos membros": novembro de 2014
Hi Guys,
I had configured the CallManager 6.0 and it was working normally. When I changed the IP of CallManager and tried to access the administration page, the CallManager didn´t accept the username and password and no error message was shown, it just asks the username and password again. When I return to the previous IP the CallManager worked again. I Collected the message bellow:
%CCM_TOMCAT_APPS-JAVAAPPLICATIONS-0-EMAppNotStarted:EM Application not started Servlet Name: Cisco Extension Mobility Application App ID:Cisco Tomcat Cluster ID:Laboratorio
I Tried to change the password, but, I get the following message error:
failed to get connection.connector(not connected:driver=com.informix.jdbc.ifxDriver
code = 1 authorization failure
Any idea?
Wilson
Correct Answer by Justin Brenton about 6 years 11 months ago
Oh your welcome!!
Overall Rating: 5 (2 ratings)
wilsonsant Thu, 08/19/2010 - 12:57
Hi Justin,
Tomorrow I will do the tests and answer for you about the results.
Thank You,
Wilson
wilsonsant Mon, 08/23/2010 - 10:20
Hi Justin,
In last friday I did the test and worked. Thanks a lot for you help.
Wilson
