DHCP server WRVS4400N
Aug 19th, 2010
Dear,
Is there a way to specify the DNS suffix of the DHCP server and to add other scope options?
It's very rudimentary, even for the small business line :-)
Tim
crankintheburn Thu, 08/26/2010 - 01:12
I need this really, really urgent, too!!!!! Any suggestions, to solve the problem?
I can't believe, they forgot this option within an enterprise product like the WRVS4400N... even the lowest budget consumer routers do have this ability.
qumartin Mon, 08/30/2010 - 17:21
There is a way to do this but this is not done on this router you would have to do this on each computer to specify each DNS suffix. Here is a link to give you more understanding of how to do this.: http://www.tech-faq.com/configuring-dns-clients.html I hope this link helps. If this is not helpful please response and i will do my best to help. Thank you for contacting cisco small business support.
