Link between two devices in CiscoWorks
Aug 19th, 2010
Hi Guy's, I wonder if you could help me with this,
I have two switches connected through a ASA (transparent) and although I know that ASA's are not supported in campus manager because of the CDP, I would like to know if the connection between these two devices will not be shown in Topology View, at least it should display a direct connection between these two.
Any qick answer will be very appreciated
Thanks in advance
Joe Clarke Fri, 08/20/2010 - 22:10
No, this will not work.  The ASA (even in transparent mode) does not forward CDP frames.  The devices will need to be directly connected to each other (or connected via a hub or non-CDP device) in order to be seen as CDP neighbors.
