PIX as a router?
Aug 19th, 2010
I have an old PIX 506, and I know the 506 supports RIP. However, can I use this simply as a router, to go from network A to B transparently, without any filtering? If I setup the outside interface to be 192.168.2.2 and the inside to be 192.168.10.1, how would I go about configuring the PIX to simply route to the inside network? Has anyone done this? Does anyone have an example config that is simply using the PIX as a router?
Nagaraja Thanthry Thu, 08/19/2010 - 18:28
  • Cisco Employee,
You can configure nonat rule to bypass the NAT.
access-list nonat permit ip
nat (inside) 0 access-list nonat
Then you can configure RIP on both interfaces.
Hope this helps.
NT
