Query & List pickup groups in CUCM 7.
Answered Question
Aug 19th, 2010
Hi All,
I have a customer who would like to list all Pickup groups with the assoicated users.
is it possible to Query, List and Extract information from the Publisher.
Charles
Correct Answer by Aaron Harrison about 6 years 5 months ago
Well.. your subject did say CUCM7....
That said, my syntax was wrong; I wrote that query in McDonalds after too many coffees and without a CCM to test against; sorry!
Try this (tested):
run sql select n.dnorpattern, n.description, pg.name as PickupName from numplan n join  pickupgrouplinemap pglm on n.pkid = pglm.fknumplan_line join pickupgroup pg on pglm.fkpickupgroup = pg.pkid
Aaron
Overall Rating: 5 (1 ratings)
Aaron Harrison Fri, 08/20/2010 - 00:21
Hi Charles
Try this command from an SSH session to the server; log the output to a text file and you can then scrub it in Excel.
I just made this up from the schema, should work but it is untested:
run sql select n.dnorpattern, n.description, pg.name as PickupName from numplan n left join n.pkid = pglm.fknumplan_line on pickupgrouplinemap pglm left join pickupgroup pg on pglm.fkpickupgroup = pg.pkid
Aaron
Please rate helpful posts...
charles-moore Mon, 08/23/2010 - 08:28
Hi Aaron,
I tried running the CLI from SSH on My Lab CUCM 6 and received the following:
ran the command into Skylab using SSH and it seems to execut, but then it comes back with:-
'A Syntax error has occurred'
It doesn't give any indication of where the syntax error is and I'm not clever enough to fathom out where the error is, so
Unless the command you wrote is only good for version 7, i'm running 6.13
Best regards,
Correct Answer
Aaron Harrison Tue, 08/24/2010 - 00:44
Try this (tested):
Aaron
charles-moore Tue, 08/24/2010 - 13:11
Hi Aaron,
Thanks alot this works a treat, I'm assuming the SQL Query could be amended to list other tables ?
Cheers Mate
Aaron Harrison Tue, 08/24/2010 - 13:26
Yep; look up the db schema on developer.cisco.com if you are curious and build 'em from there...
Aaron
