CUCM 7.1.3 and IOS Gateway for Enhanced Conferencing
Answered Question
Hi all,
I have a 3825 IOS gateway configured for Enhanced Conferencing. I just recently upgraded from CCM 4.1.3 to CUCM 7.1.3 but I forgot to update the CUCM version in the SCCP CCM list in the 3825 IOS gateway (please see example below).Could someone tell me if this is something that I can change on the fly without affecting production ? Is there anything else that I need to be aware of when making this change ?
sccp ccm x.x.x.x identifier 2 priority 1 version 4.1
Everything is working fine at the moment but I would like to update the version to the same version of CUCM that's currently in production.
Thanks all in advance !!!
D.
Correct Answer by David Hailey about 6 years 10 months ago
D. Tran,
You won't "hurt" anything by changing the version identifier.  In fact, if I remember correctly the version identifier is related to the the Enhanced IOS conference bridge configuration.  However, you will have to issue a "no sccp" in order to make this change so the impact is that the gateway will unregister and then re-register after you make configuration changes and issues the "sccp" command to turn SCCP back on.  Depending on your environment, this may be something you'd prefer to do during a really quick off-hours time window.
Hailey
Please rate helpful posts!
Overall Rating: 5 (1 ratings)
Correct Answer
David Hailey Thu, 08/19/2010 - 17:46
  • Purple, 4500 points or more
D. Tran,
Hailey
