pan with WVC210
Aug 19th, 2010
Panning never seems to work on the WVC210. Tried a couple of units and still the same result. What am I doing wrong? Is there a firmware update? Should I be using the client install instead of the web? Is this a manufacturing defect?
asarutan Fri, 08/20/2010 - 12:34
Have you tried going to the Pan/Tilt page and do a Calibration?
Alan.
miranda.a Fri, 08/20/2010 - 13:17
Yes.
asarutan Fri, 08/20/2010 - 13:20
Does it go through pan and tilt while calibrating or just tilt with no panning?
Alan.
miranda.a Fri, 08/20/2010 - 13:23
no panning?
It only tilts.
asarutan Fri, 08/20/2010 - 13:35
How many cameras do you have that's like that? Have you tried factory reset? If yes and the result is still the same then I would RMA those units. However I am puzzled to find that all (I assume you have more than one) of them behave exactly the same.
Alan.
miranda.a Fri, 08/20/2010 - 18:39
I'm puzzled too. I've tried two others. So this verifies that pan IS a
feature. I already returned them. They're Fry's problem now. Hopefully
I can find a better lot at another store. All else fails, a different
camera all together.
