ACS 5.1 Radius
Aug 20th, 2010
I am trying to set up user authentication against AD / Radius. Then assign either Guest user access or known user access depending on credentials.  I am encountering the following output from deb radius authentication on my switch (Cat 3750) - yet the server is reachable via ping.
00:58:28: RADIUS: Tried all servers.
00:58:28: RADIUS: No valid server found. Trying any viable server
00:58:28: RADIUS: No response from (,1646) for id 1645/17
could anyone help me identify where the configuration error is ?
jackwikinski Fri, 08/20/2010 - 02:21
The first thing I would check is the key is the same at both ends. Also ensure that 1645 and 1646 is also configure at both ends. Lastly if you have a firewall that the appropriate rules are configured.
הודעה מקורית
KeithN123 Fri, 08/20/2010 - 02:24
thanks Jack - I have already checked the key - but finding my way around the
ACS 5.1 system is a bit of a minefield.....I will check the ports are correct though.
