Cat 3750 Web Config ie 7
Aug 20th, 2010
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin-top:0cm; mso-para-margin-right:0cm; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0cm; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;}
Hi All,
We've been upgrading to Internet Explorer 7 and we've realised that the current web server on our Cisco switches doesn't like this browser. Does anyone know if this is this fixed in latest version of the IOS? All I can get from CCO is the supported OS rather than supported browsers.
Currently, we have C2950-I6Q4L2-M version 12.1(22) EA4 on our Cat 2950s and C3750-IPBASE-M, Version 12.2(35) SE5 on our Cat 3750s, though we do have a few stacks with C3750-IPservicesk9-M version 12.2(35) SE2
Cheers
J
Nagaraja Thanthry Fri, 08/20/2010 - 06:05
Are you using CNA? If you are just accessing the switch IP over the browser,
most likely the issue is with Java compatibility. Please make sure that the
Java version you are using on IE7 is the same as the previous version (or
higher).
Here is a link with troubleshooting steps.
http://www.cisco.com/en/US/products/hw/switches/ps607/products_tech_note...
6a0080094709.shtml#topic2
Hope this helps.
NT
