catalyst 2900 destination MAC change
Aug 20th, 2010
hello,
I'm facing some problem in my, very specific, network. All the machines are connected to a Catalyst 2900 and they all have the same IPs and MAC addresses. Is there a way to change a destination MAC address on the switch? Or, somehow, forward traffic via a specific swith port basing on some information in data?
regards,
Artur Stepniak
Nagaraja Thanthry Fri, 08/20/2010 - 06:58
  • Cisco Employee,
Unfortunately, the switch cannot get into the packet and inspect the
contents. So, you need to find a different way to achieve what you are
looking for.
When you say all devices have same IP and same MAC, are you referring to a
load balancing environment? If it is a load balancing environment, you can
manually configure the switch to register the MAC address on all ports and
then switch will forward a copy of the packet to every port. Each server can
decide if it wants to process the data and reply. Here is a document on
Microsoft NLB for Cisco Switches.
http://www.cisco.com/en/US/products/hw/switches/ps708/products_configura...
_example09186a0080a07203.shtml
Hope this helps.
NT
Related Content
