Unity connections. Database.error-271
Answered Question
Hi all
I keep getting the above error when trying to add/delete users and have some other strange issues like not playing messag
es on the first attempt but repeating it works.
When looking at the licensing we get a lot of the followoing errors.
"There was an unexpected failure exectuting a database stored procedure execute procedure UnityDirDb:csp_licenseStatusModify ( pObjectID = '4bd919e0-52d8-4924-87d8-cc919af996ef,pComplianceTime='2010-08-20 10:36:00,828':. Please restart your system or contact support personnel if this failure continues."
The only link i have found implies a lic issue.
Any help appreciated
Correct Answer by Rob Huffman about 6 years 6 months ago
Hi David,
Definitely a License issue
It shows that your "Temporary" license has expired;
If you have a Permanent license, it needs to be loaded and activated via the UC Admin>Licenses
Cheers!
Rob
Overall Rating: 5 (4 ratings)
Correct Answer
Rob Huffman Fri, 08/20/2010 - 07:00
Hi David,
Cheers!
Rob
Bradford Magnani Fri, 08/20/2010 - 07:06
In addition to Rob's comment (+5), if you're on an old version of UC ie: 7.0(x), you may be hitting the nasty database defect mentioned in another post by TAC here: https://supportforums.cisco.com/docs/DOC-9120  If so, I highly recommend you plan to upgrade; aiming for 7.1(5) or 8.x range of code.
Hope that helps,
Brad
David Hailey Fri, 08/20/2010 - 07:08
Just to add to Rob's post, when you receive a temporary license it has an expiration date and a compliance date.  The expiration date is the date that the license is no longer "valid"; however, Cisco provides a grace period before the system is impacted by having an invalid, expired license installed.  I don't recall the exact amount of time allowed but I believe it is 30 or possibly 60 days...but the compliance date reflects the expiration + the allowed grace period.  You'll need to contact [email protected] to obtain a permanent license.
Hailey
Please rate helpful posts!
