7600 vty and console hangs
Aug 20th, 2010
We have problems with the vty and console. When we introduced a command (show run, show tech for example) the lines vty / console hangs after few seconds and is not possible to reset them.
The routers was restarted but the behavior is the same.
Regards.
m.arancibia Fri, 08/20/2010 - 07:12
Cisco IOS Software, c7600s72033_rp Software (c7600s72033_rp-ADVIPSERVICESK9-M), Version 12.2(33)SRC2, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Thu 18-Sep-08 12:02 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)S4, RELEASE SOFTWARE (fc1)
