ACS 5.1 Username prefix strip doesn´t work
Aug 20th, 2010
Hi guys, Do you know if it´s a bug in the ACS v5.1 related with the Username prefix strip when you use LDAP servers as authentication server?
I have a deployment using LDAP and 802.1x wired, the ACS received DOMAIN\User but it doesn´t strip the domain portion of the user and the LDAP server doesn´t find the user in that format.
Gerard
Javier Henderson Fri, 08/20/2010 - 09:16
  • Cisco Employee,
What do the details on the activity log show as being sent to the LDAP server?
Can you include a screenshot of your LDAP configuration (the directory organization tab)?
gerardtorin Fri, 08/20/2010 - 10:23
Hi Javier, I was wrong.
The problem was that PEAP-MSCHAP2 is not supported with LDAP Servers.
Gerard
