Re: Cisco 1121 Access Point
Aug 20th, 2010
I have three Cisco 1121 AP which have stopped working.  Connectivity to the AP is intermitent,  for  the first 5 minutes I am able to connect to the AP through the web browser, when i check the radio on the AP it is administratively down, protocol down,. When i try to enable the radio it does not come up. I access the AP through the CLI and I am experiencing the same problem. Has anyone seen this proble before?
Note the AP is only up for about 6- 7  minutes after this I am not able to connect to the device
m-laing Mon, 08/23/2010 - 12:33
See below output of the show log
log
Syslog logging: enabled (0 messages dropped, 3 messages rate-limited,
0 flushes, 0 overruns, xml disabled, filtering disabled)
Console logging: disabled
Monitor logging: level debugging, 0 messages logged, xml disabled,
filtering disabled
Buffer logging: level debugging, 17 messages logged, xml disabled,
filtering disabled
Logging Exception size (4096 bytes)
Count and timestamp logging messages: disabled
Trap logging: level informational, 22 message lines logged
More
Log Buffer (4096 bytes):
*Mar 1 00:00:05.137: %LINK-5-CHANGED: Interface Dot11Radio0, changed
state to reset
*Mar 1 00:00:05.137: %DOT11-4-LOADING_RADIO: Interface Dot11Radio0,
loading the radio firmware (flash:/c1100-k9w7-mx.123-4.JA2/5101.img)
*Mar 1 00:00:08.121: %LINK-3-UPDOWN: Interface FastEthernet0, changed
state to up
*Mar 1 00:00:08.432: %SYS-5-CONFIG_I: Configured from memory by console
*Mar 1 00:00:08.433: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C1100 Software (C1100-K9W7-M), Version 12.3(4)JA2,
RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Fri 31-Mar-06 16:08 by kellythw
*Mar 1 00:00:08.433: %SNMP-5-COLDSTART: SNMP agent on host ap is
undergoing a cold start
*Mar 1 00:00:08.454: %DOT11-4-NO_SSID: No SSID configured. Dot11Radio0
not started.
*Mar 1 00:00:09.120: %LINEPROTO-5-UPDOWN: Line protocol on Interface
FastEthernet0, changed state to down
More *Mar 1 00:00:09.328:
%LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar 1 00:00:09.452: %LINEPROTO-5-UPDOWN: Line protocol on Interface
Dot11Radio0, changed state to down
*Mar 1 00:00:17.036: %LINEPROTO-5-UPDOWN: Line protocol on Interface
FastEthernet0, changed state to up
*Mar 1 00:00:52.983: %LINEPROTO-5-UPDOWN: Line protocol on Interface
*Mar 1 00:00:54.983: %LINK-3-UPDOWN: Interface BVI1, changed state to
down
*Mar 1 00:00:55.983: %LINEPROTO-5-UPDOWN: Line protocol on Interface
BVI1, changed state to down
*Mar 1 00:00:57.036: %LINEPROTO-5-UPDOWN: Line protocol on Interface
*Mar 1 00:01:00.261: %LINK-3-UPDOWN: Interface BVI1, changed state to up
*Mar 1 00:01:01.261: %LINEPROTO-5-UPDOWN: Line protocol on Interface
ap#
ap#sh run
Building configuration...
Current configuration : 1603 bytes
version 12.3
no service pad
service password-encryption
hostname ap
no logging console
enable secret 5 $1$VvYY$dNqVcfo2cT0d5PDuMRzPe.
username Cisco password 7 112A1016141D
ip subnet-zero
ip dhcp excluded-address 10.0.0.1 10.0.0.10
ip dhcp pool local-default-pool
network 10.0.0.0 255.255.255.224
default-router 10.0.0.1
lease 0 0 1
More !
no aaa new-model
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
short-slot-time
speed basic-5.5
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface FastEthernet0
no ip address
More no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address 10.0.0.1 255.255.255.224
no ip route-cache
ip http server
no ip http secure-server
ip http help-path
http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
logging snmp-trap emergencies
logging snmp-trap alerts
logging snmp-trap critical
logging snmp-trap errors
logging snmp-trap warnings
control-plane
More !
bridge 1 route ip
line con 0
transport preferred all
transport output all
line vty 0 4
login local
transport input all
line vty 5 15
login
transport input all
end
ap# config t
Enter configuration commands, one per line. End with CNTL/Z.
ap(config)#int
% Incomplete command.
ap(config)#
ap(config)#int Dot11Radio0
ap(config-if)#no shut
ap(config-if)#exit
ap(config)#exit
ap#sh logs
filtering disabled
Buffer logging: level debugging, 18 messages logged, xml disabled,
filtering disabled
Trap logging: level informational, 23 message lines logged
More
state to reset
state to up
not started.
down
*Mar 1 00:04:53.100: %SYS-5-CONFIG_I
leolaohoo
To:
Marsha Laing/Jamaica/[email protected]
Date:
08/20/2010 08:56 PM
Subject:
New message: "Re: Cisco 1121 Access Point"
m-laing,
A new message was posted in the Discussion thread "Re: Cisco 1121 Access
Point":
https://supportforums.cisco.com/message/3161952#3161952
Author : leolaohoo
Profile : https://supportforums.cisco.com/people/leolaohoo
Message:
Leo Laohoo Mon, 08/23/2010 - 15:55
*Mar  1 00:00:08.454: %DOT11-4-NO_SSID: No SSID configured. Dot11Radio0 not started.
This is the culprit.
