Additional WDS
Aug 20th, 2010
Dear Experts,
I have Cisco Aironet 1130 WAP providing WDS service and local radius authentication to Client AP's.
As per Cisco Documents, only 60 clients can be added (with radio diabled of WDS server)  to WDS Domain and we have 90 WAP.
So when I try to add 61,limitation error recieved. Now my question is that "Is is possible to add additional WDS
in the same subnet to overcome this problem ?"
I can provide WDS configuration if asked.
Any help will be appreciated.
Overall Rating: 4.3 (3 ratings)
Stephen Rodriguez Fri, 08/20/2010 - 10:31
  • Purple, 4500 points or more
Yes.  The VLAN the AP is in is for managing the AP, although you can put clients on this VLAN if you like.  On the AP you define dot1q encapsulated subinterfaces to link the cilents into the appropriate VLAN.
Abdul Samir Shaikh Fri, 08/20/2010 - 10:44
I have attached a sample configuration of WAP.
And switch configuration
interface gigaethernet 0/16
switchport trunk native vlan 25
switchport trunk allowed vlan 1,11,25
switchport mode trunk
Now you can see the AP configuration that its default gateway is 20.20.0.1 (Vlan 25)
What would of the configuration of a new WDS. If i keep in other subnet
Any suggestions.
Stephen Rodriguez Fri, 08/20/2010 - 14:58
The only thing you would really have to change is what subinterfaces are "native".  If you put the AP in VLAN 30, then the encapsulation dot1q 30 native instead of 25 native, etc
Abdul Samir Shaikh Fri, 08/20/2010 - 15:32
Thanks for the support. Now all the things have been cleared regrading vlans,trunk etc.
Only last question The configuration of Client should be simila with WDS in relation to interfaces,subinterfaces,ssid's,encryption,
For example i created interface dot11radio 0.1 on a client, the same should be configured on WDS
Will these cahnges affect authenticating to WDS server.
really appreciated
Stephen Rodriguez Fri, 08/20/2010 - 15:53
no, for WDS if it's not servicing clients doesn't even need the subinterfaces, all the config for the client auth is under the WLCCP config for what AAA groups to point to.  But if you are just looking to template the configs, then you could make them all match with the exception of name and IP and have no issues.
Abdul Samir Shaikh Fri, 08/20/2010 - 15:57
Thanks for your precious time you gave to clear my doubts
can i have your e-mail (if u dont mind) nncase if i want to ask i contact through email
