08-20-2010 09:23 AM - edited 03-11-2019 11:28 AM
Hi all!
I have static IP (outside). Let's say it is 69.70.90.90.
I want to map https://69.70.90.90:8080 to internal https://192.168.1.2:443
But it doesn't seems to woks. How I do this?
08-20-2010 09:34 AM
this is what you need if you are running 8.2 and prior
static (inside,outside) tcp 69.70.90.90 8080 192.168.1.2 443
so basically the first field is translated and second is real
08-20-2010 09:36 AM
Please try the following:
static (inside,outside) tcp 69.70.90.90 8080 192.l68.1.2 443 netmask
255.255.255.255
access-list outside_access_in permit tcp any host 69.70.90.90 eq 8080
access-group outside_access_in in interface outside
If you already have an access-list, then you can append that access-list
with the new line. Also, if 69.70.90.90 is the interface IP address, you
need to use the "interface" keyword instead of the address.
static (inside,outside) tcp interface 8080 192.l68.1.2 443 netmask
255.255.255.255
access-list outside_access_in permit tcp any interface outside eq 8080
Hope this helps.
NT
