Issue converting a 881W from LWAPP to Autonomous mode
Aug 20th, 2010
Hi everybody,
It may stupid but I was trying to upgrade the IOS image of the AP and I did a wrong manip.
I downloaded the IOS image (ap801-rcvk9w8-tar.124-10b.JA3.tar) from my TFTP server to the flash of the AP. Everything went find so far.
But than I did an archive archive download-sw /overwrite ap801-rcvk9w8-tar.124-10b.JA3.tar and my AP reboot in LWAPP mode.
I should have done: archive download-sw /overwrite tftp://10.0.0.1/ ap801-rcvk9w8-tar.124-10b.JA3.tar instead!
Now I don't how to go back to autonomous mode. archive commando is not available anymore in LWAPP mode.
Any ideas?
Best regards,
Laurent
Overall Rating: 4.9 (5 ratings)
lap@axcess.dk Sat, 08/21/2010 - 02:48
A bit more details to my previous post to help you troubleshoot my issue.
On the router (881W) I did :
881W#service-module wlan-ap 0 reset bootloader
so I could access the bootloader of the AP. Now I have the following prompt:
ap:
I did format all the flash with this commando:
ap: format flash:/
Are you sure you want to format "flash:" (all data will be lost) (y/n)?y
flashfs[0]: 0 files, 1 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 31481856
flashfs[0]: Bytes used: 1024
flashfs[0]: Bytes available: 31480832
flashfs[0]: flashfs fsck took 43 seconds.
Filesystem "flash:" formatted
But now I don't know how to load the correct IOS image on the AP to go back to autonomous mode. Any ideas?
Best regards,
Laurent
lap@axcess.dk Sat, 08/21/2010 - 04:56
Well actually I solve the problem. I just want to explain what I did for people who are running in the same kind of problem.
First of all in the AP bootloader I did:
ap: ether_init
Initializing ethernet port 0...
ap: tftp_init
tftp_init success: You can now use tftp file system!
ap: flash_init
Than I checked the IP address of the AP:
ap: set
DEFAULT_ROUTER=10.0.0.1
IP_ADDR=10.0.0.1
NETMASK=255.255.255.224
Than I configured my PC on the same subnet and on the router I configured the switchport F0 to be on the same subnet as the AP:
interface FastEthernet0
switchport access vlan 2
interface wlan-ap0
description Service module interface to manage the embedded AP
ip unnumbered Vlan2
interface Wlan-GigabitEthernet0
description Internal switch interface connecting to the embedded AP
interface Vlan2
ip address 10.0.0.2 255.255.255.224
Than I did in the bootloader:
ap: copy tftp://10.0.0.5/ap801-k9w7-tar.124-21a.JY.tar flash:/ap801-k9w7-tar.124-21a.JY.tar
where 10.0.0.5 is my PC IP where I have an TFTP server.
Once you have downloaded it you have to extract the image (Verify to download the right one. Not the LWAPP one) like that:
ap: tar -xtract flash:/ap801-k9w7-tar.124-21a.JY.tar flash:/
It can take a while.
Once it is extracted just type:
ap: boot
Than you should be find.
Don't forget to rate the post if you think it is useful.
Best Regards,
Laurent
sanjeewa Wed, 05/02/2012 - 08:54
Thank you Laurent, very nice of you to spend time writing that process
Kind regards
Sanjeewa
semblantesf Fri, 03/21/2014 - 21:19
Perfect. Thank you for your help. I applied this method to convert AIR-CAP2602E-A-K9 to Autonomous Mode witch image ap3g2-k9w7-tar.152-2.JB.tar.
I had a error:
Error writing flash://ap3g2-k9w7-mx.152-2.JB/Y5.bin (Not enough space on device)
I did format the flash with command: format flash:/
This process take very long time (1 hours), but is successfully.
