Cisco 526 wireless Controller & AP AIR-AP521G-A-K9 -Question
Answered Question
Aug 20th, 2010
  • Green, 3000 points or more
We have several  AP 521  in our main  HQ building as well as our remote branch offices ,  totalling  about  16 AP ,  four in our Main HQ office and one in each remote brachh.    All AP at this time are Standalone devices.
We are contemplating  centralized management of ALL  our AP devices   by implementing  this 526 controller, where we can easy manage mac access-list or other settings  .
Here are my questions based on reading some basic documentation on the 526 controllers:
1- I undersland these AP models and  526 Controller model are EOL,   -  when  are these End of Support - At this time we are not planing to migrate to newer AP devices yet , perhaps in the next 2 to 3 years down the road, but definatetly SmartNET is a must on these .
2- For 526 be able to manage any AP device , does the AP  device has to be converted onto LAP , is this correct?
3-As I read , the 526 controller can support up to 6 AP 521 devices ,   if this is the case can I for example.. say install one 526 controller  in main HQ that only has FOUR AP wireless devices and be able to also manage 2 more AP devices from REMOTE offices  that are not directly connected to HQ main office switches  but have connectivity  that are across our MPLS  WAN links ,  or do they (the AP wireless devices ) need to be directly connected to the LAN   in order for the 526 be able to manage the devices , if this is feasable then that would allow me to implement 3 526 controllers in HQ office to be able to manage all 16 AP devices from our entire company..  please correct me if this is not true.
4- And lastly,  for example , say  I have MAC acls applied to each of AP devices,  now with teh 526 controlller  if we were to go about using centralized management  would I be able to create a MAC acl and tell the controller to propagate the ACL to ALL AP devices that are under its management ?
Thank you for  your assistance
Correct Answer by Lucien Avramov about 6 years 9 months ago
1. Here is the end of life announcement:
http://www.cisco.com/en/US/prod/collateral/wireless/ps7306/ps7320/ps7339/end_of_life_c51-568040.html
2. Yes LWAPP APs are easier to manage from the 526:
http://www.cisco.com/en/US/prod/collateral/wireless/ps7306/ps7320/ps7339/product_data_sheet0900aecd8060c22b.html
3. You will be fine over MPLS to have AP joining a remote controller. You may need to tweak the MTU if you have issues with the AP joining.
However, remember that if you're MPLS link goes down, you will loose connectivity, so this is here a design decision to make.
4. Per the feature list you should be able to:
http://www.cisco.com/en/US/docs/wireless/controller/526/1.5/configuration/guide/A3_feature_list.html
Overall Rating: 5 (1 ratings)
Correct Answer
Lucien Avramov Sat, 08/21/2010 - 13:31
  • Red, 2250 points or more
Trending Topics - Security & Network
