08-20-2010 12:32 PM - edited 03-14-2019 06:20 AM
I'm trying to install the CUIC 8.0.0.
I've finished the installation and start the services in the console, but the Web Browser interface doesn't appear, and I didn't find any manuals to help myself.
Thanks.
Denian Nascimento
09-06-2010 08:28 AM
Hi Denian,
Have you installed the license? You have to go to http://
Hope that helps.
JD
09-06-2010 08:42 AM
OK, I'll try it and report to you.
Thanks.
Denian Nascimento
09-21-2010 06:24 AM
Thanks for the help, now CUIC8 appears, but when I try to upload the License the next errors appears:
"License file is invalid. Invalid host. The hostid of this system does not match the hostid specified in the license file "
I generated a Demo License on: https://tools.cisco.com/SWIFT/Licensing/PrivateRegistrationServlet with both MACs, the MAC License (that is the correct) and the MAC Adress (just to confirm), but neither MAC License nor MAC Adress work.
Thanks.
Denian Nascimento.
09-22-2010 03:13 AM
I too have had this problem in the past and have had to contact 'licensing@cisco.com' to get it resolved.
Cheers,
JD
09-24-2010 06:06 AM
Thanks for the help, I sent an e-mail to licensing@cisco.com , now I'll wait for the answer.
Thanks very much.
Denian Nascimento
