Remote Access to Secure Series 500 router
Answered Question
Aug 20th, 2010
Hi all, I know this question is probably asked all the time but I am wanting to allow remote access through ssh and possibly telnet from WAN on a secure series 500 router.  I've configured the firewall settings with the Cisco Configuration Assistant mostly.  Is there any step-by-step way that normally works for allowing these connections and if so could you give me a step-by-step example.  I greatly appreciate it.
Correct Answer by Federico Coto F... about 6 years 11 months ago
Normally you would not want to allow telnet on the WAN side (unless is your only option).
To configure SSH, you need an IOS image that supports encryption ''shows k8/k9 on the image name''
Normally to configure SSH, you do the following:
Configure hostname
Configure domain-name
Generate RSA keys
Enable AAA with a local user
Authenticate SSH agains the local database
Federico.
Overall Rating: 5 (1 ratings)
Correct Answer
Federico Coto F... Thu, 08/26/2010 - 18:03
  • Green, 3000 points or more
Configure hostname
Generate RSA keys
Federico.
Joseph E Spoon Thu, 09/12/2013 - 21:48
This worked thank you for your response.  Going through past discussions.
