Dot11 Radio 'x'
Aug 20th, 2010
Device: Cisco AIR AP1240 Switch configured as a Bridge that is connected and associates with AP's in a WLAN.
Question: What is the significance of the Virtual-Dot11 Radio' s associated with the device? For example, virtual-dot11radio3.
Leo Laohoo Fri, 08/20/2010 - 18:13
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Virtual Radio is a "virtual" link between the root bridge and the non-root bridge.  It's also a very, very good way of troubleshooting.  If you don't see the virtual radio interface then your point-(multi-)point bridge isn't working.
SSysouvanh Mon, 08/23/2010 - 06:04
If there are more than one virtual radio, if one is down, does this mean the BR as a whole is down?
Leo Laohoo Mon, 08/23/2010 - 15:59
  • Hall of Fame,
    2017 LAN, Wireless
No.  If you have two radios and, say, you configured two different bridges.  This means you'll have two virtual radios.  If one goes down, then the remote goes down (obviously) but the second one can remain up.  It all depends on your configuration, the range, the signal strength, etc.
