How to configure WPA on Aironet 1300 without using RADIUS
Answered Question
I'm trying to set up a couple of Aironet 1300s. I want to use WPA, but I don't have a radius server.Is it possible to configure then 1300s to use WPA with a password and not a RADIUS server? Thanks.
Correct Answer by Stephen Rodriguez about 6 years 8 months ago
Yes this is possible.  Under the Radio you call the encryption method you want to use:
encryption mode ciphers tkip
then under the ssid:
dot11 ssid Test
authenticaiton open
authenticaiton key-managment wpa
wpa-psk ascii 0 cisco1234
So long as the encryptions and keys match on both sides, and one is root bridge and the other nonroot they should bridge just fine
Overall Rating: 5 (1 ratings)
Correct Answer
Stephen Rodriguez Fri, 08/20/2010 - 15:54
  • Purple, 4500 points or more
dot11 ssid Test
authenticaiton open
Related Content
