Cisco 2600 Router - home network
Answered Question
Aug 20th, 2010
I have a 2600 router that I setup in 2007 for use in a home network.  Due to sitting with no power since 2008, the config is lost.  Basically I don't remember anything about programming routers.  I've spent the day researching and trying to remember.
My network setup consists of 1 internet IP address and a dhcp pool of 172.16.1.0/24.  I don't want any restrictions of outbound connections.  I don't want any allowed inbound connections just yet.  So far I connected my laptop to fa0/1 and my internet to fa0/0.  From the terminal inside the router I can ping anywhere I like, including resolving hostnames.  From my laptop I can ping the internal and external addresses of the router, but no farther.  Something isn't clicking right in my crazy head and it's getting late.  I was hoping for a little help on completing this.  Below is my (shortened) config.
One note about the access-list before you read the config.  I have access-list 1 to permit any.  I set access-group 1 in and out on both fa0/0 and 0/1 just to see.  No success.  I removed them until I got it right.  So that is why you don't see it in the config.  I'm not even sure which is supposed to be set at this point.  Hopefully I'll have a cleaerer head on the subject in the morning.
Current configuration : 1403 bytes
version 12.3
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
no network-clock-participate slot 1
no network-clock-participate wic 0
voice-card 1
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 172.16.1.1 172.16.1.99
ip dhcp excluded-address 172.16.1.250 172.16.1.255
ip dhcp pool home
   network 172.16.1.0 255.255.255.0
   dns-server 208.67.222.222 208.67.220.220
   default-router 172.16.1.1
interface FastEthernet0/0
ip address 216.xxx.yyy.zzz 255.255.255.0
ip nat outside
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
no dce-terminal-timing-enable
interface FastEthernet0/1
ip address 172.16.1.1 255.255.255.0
ip nat inside
duplex auto
speed auto
ip classless
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0
ip http server
ip nat pool home 216.xxx.yyy.zzz 216.xxx.yyy.zzz prefix-length 24
access-list 1 permit any
Correct Answer by kyukim about 6 years 7 months ago
You are missing a NAT statement to connect ACL and NAT POOL and do NAT translation.
"ip nat inside source list 1 pool home"
Read below link for more detail.
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080094e77.shtml#topic4
And, let me if it is not working.
Have a good weekend.
KK
Overall Rating: 5 (1 ratings)
the1337bofh Sat, 08/21/2010 - 07:58
KK,
That was perfect and exactly what I was looking for. I knew I needed to
connect them all together somehow, but couldn't think of how for the life of
me. Thank you very much. I also changed my access to only permit
172.16.1.0/24 as I should have done last night.
If you have time for one more question, I would be grateful. I am trying to
map port 80 to my web server, and I'm falling a bit short. I have several
PDF documents and a few webpages listed here that all say the same thing,
however it isn't quite working. Here is what I have tried.
ip nat inside source static tcp 172.16.1.100 80 216.xxx.yyy.zzz 80
extendable
