Stumped on tryng to configure a 1711
Answered Question
Aug 21st, 2010
Hello. I am trying to assist a client with configuring their 1711 with a VPN tunnel going back to their main office. They have several routers set up in much the same way (see config below). I plugged this router in, setup the configuration with the correct ip's (checked several times) and now I am stuck.
I am able to ping outside addresses (such as 4.2.2.2) from the router console. I am not able to contact those same sites from my PC that is directly connected to Fe4.
I am able to ping from my pc, the gateway installed in the router (10.1.6.1), and from the router console I am able to ping my PC.
So from the router console: I can ping internet addresses and LAN addresses
From my PC: I can ping the routers internal IP, but nothing else.
I seem to think the issue is with the way they have Vlan1 set up on teh 1711, but I cannot see what the issue is. like I said, they have several configs just like this at other sites, and they are working just fine. Can anyone point me in the right direction?
Just to be clear, I haven't even gotten to the point where I've tried to establish the tunnel on the other end. I am just trying to get from my lan (10.1.6.x) out to the internet, throgh this router.
Thanks for any help.
version 12.3
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service compress-config
service sequence-numbers
hostname Routername
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 64000 warnings
username asdadf password 7 0016071417asdf5A1845fad0833494B07
username 23wwfa privilege 15 password 7 asdf23qwrt32asdg3
clock timezone EST -5
clock summer-time EST date Apr 6 2003 2:00 Oct 26 2003 2:00
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no aaa new-model
ip subnet-zero
no ip source-route
no ip domain lookup
ip domain name domainname.local
no ip bootp server
ip cef
ip inspect name DEFAULT100 cuseeme
ip inspect name DEFAULT100 ftp
ip inspect name DEFAULT100 h323
ip inspect name DEFAULT100 netshow
ip inspect name DEFAULT100 rcmd
ip inspect name DEFAULT100 realaudio
ip inspect name DEFAULT100 rtsp
ip inspect name DEFAULT100 smtp
ip inspect name DEFAULT100 sqlnet
ip inspect name DEFAULT100 streamworks
ip inspect name DEFAULT100 tftp
ip inspect name DEFAULT100 tcp
ip inspect name DEFAULT100 udp
ip inspect name DEFAULT100 vdolive
ip inspect name DEFAULT100 icmp
ip ids po max-events 100
ip ssh time-out 60
ip ssh authentication-retries 2
ip ssh version 2
login quiet-mode access-class 123
no ftp-server write-enable
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp key as2323sa433 address x.x.x.x
crypto ipsec transform-set SDM_TRANSFORMSET_1 esp-3des esp-sha-hmac
crypto map SDM_CMAP_10 1 ipsec-isakmp
description Tunnel to DataCenter
set peer x.x.x.x
set transform-set SDM_TRANSFORMSET_1
match address GRE2DATACENTER
interface Tunnel0
description VPN to DataCenter Fiber
bandwidth 2048
ip address 10.254.253.30 255.255.255.252
no ip redirects
no ip proxy-arp
ip mtu 1338
ip hello-interval eigrp 10000 20
ip hold-time eigrp 10000 60
ip route-cache flow
ip tcp adjust-mss 1200
cdp enable
tunnel source FastEthernet0
tunnel destination x.x.x.x.x
interface Null0
no ip unreachables
interface Loopback100
ip address 10.254.1.14 255.255.255.255
no ip redirects
no ip proxy-arp
ip route-cache flow
interface FastEthernet0
description Connected to Internet
ip address x.x.x.x y.y.y.y
ip access-group 123 in
no ip redirects
no ip proxy-arp
ip nat outside
ip inspect DEFAULT100 out
ip virtual-reassembly
ip route-cache flow
duplex auto
speed auto
no cdp enable
crypto ipsec df-bit clear
interface FastEthernet1
no ip address
shutdown
interface FastEthernet2
no ip address
shutdown
interface FastEthernet3
no ip address
shutdown
interface FastEthernet4
no ip address
interface Vlan1
description Connected to Datacenter
ip address 10.1.6.1 255.255.254.0
ip helper-address 10.0.2.11
no ip redirects
no ip proxy-arp
ip nat inside
ip route-cache flow
interface Async1
no ip address
router eigrp 10000
passive-interface Vlan1
passive-interface FastEthernet0
network 10.0.0.0
no auto-summary
eigrp stub connected
ip classless
ip route 0.0.0.0 0.0.0.0 y.y.y.y (next hop)
ip route x.x.x.x (tunnel address) 255.255.255.255 y.y.y.y (next hop)
no ip http server
ip http access-class 1
ip http authentication local
no ip http secure-server
ip access-list extended GRE2DATACENTER
permit gre host x.x.x.x host y.y.y.y
access-list 1 permit 10.1.14.0 0.0.1.255
access-list 1 permit 10.0.0.0 0.0.255.255
access-list 1 permit 10.1.6.0 0.0.1.255
access-list 123 permit esp any any
access-list 123 permit ip host x.x.x.x host y.y.y.y
access-list 123 permit icmp host x.x.x.x host y.y.y.y
access-list 123 permit icmp any host y.y.y.y unreachable
access-list 123 permit icmp any host y.y.y.y time-exceeded
access-list 123 permit icmp any host y.y.y.y echo-reply
access-list 123 permit icmp any host y.y.y.y source-quench
access-list 123 permit icmp x.x.x.x 0.0.0.7 host y.y.y.y
access-list 123 permit udp host x.x.x.x host y.y.y.y eq isakmp
access-list 123 permit udp host 192.5.41.41 eq ntp host y.y.y.y eq ntp
access-list 123 permit tcp 192.5.32.0 0.0.1.255 any range ftp-data 22
access-list 123 permit tcp 192.5.34.0 0.0.0.255 any range ftp-data 22
access-list 123 permit tcp host x.x.x.x any range ftp-data 22
access-list 123 permit tcp any host y.y.y.y eq telnet
access-list 123 permit ip x.x.x.x 0.0.7.255 any
access-list 123 permit ip x.x.x.x 0.0.0.255 any
access-list 123 deny   ip 10.0.0.0 0.255.255.255 any
access-list 123 deny   ip 172.16.0.0 0.15.255.255 any
access-list 123 deny   ip 192.168.0.0 0.0.255.255 any
access-list 123 deny   ip 127.0.0.0 0.255.255.255 any
access-list 123 deny   ip host 255.255.255.255 any
access-list 123 deny   ip host 0.0.0.0 any
access-list 123 deny   ip any any log
snmp-server community publicsum#blue RO
snmp-server community privatesum#blue RW
snmp-server community ripcord RO 3
snmp-server enable traps tty
snmp-server host 10.0.2.11 publicsum#blue  syslog
control-plane
line con 0
logging synchronous
login local
line 1
stopbits 1
speed 115200
flowcontrol hardware
line aux 0
line vty 0 4
logging synchronous
login local
line vty 5 15
logging synchronous
login local
transport input ssh
end
Correct Answer by Nagaraja Thanthry about 6 years 10 months ago
I do not see NAT rules configured on the router. Can you try the following:
access-list 1 permit 10.0.0.0 0.255.255.255
ip nat inside source list 1 interface fa 0 overload
Hope this helps.
NT
Overall Rating: 5 (1 ratings)
Correct Answer
Nagaraja Thanthry Sat, 08/21/2010 - 17:13
  • Cisco Employee,
Hope this helps.
NT
jarednwesley Sat, 08/21/2010 - 17:40
Geez, you're probably right. I've been staring at that config for a good part of the day (albeit on 3
hours of sleep (long DC move)). I'll try that and let you know tomorrow. Thank you for taking the time to look at it.
jarednwesley Sun, 08/22/2010 - 08:31
Yep. That was it. Such a simple answer, but it completely escaped me. Thank you for your help.
