Minutes Based Calling
sohaildxbfze
Hi All,
I was searching any option from Cisco UC that can offer minutes-based calling options for a partition OR extension.
Any body knows how to acheive this in Cisco UC, or using any other VAS solution
And I have replied, thanks.
8 Replies 8
Justin Brenton
Level 4
Level 4
Can you please explain a bit further.
Time of Day routing maybe what your looking for.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a0080a7bc96.shtml
HTH, Please rate if so.
Justin
sohaildxbfze
Hi there,
No its not TOD (Time of day routing).
Its like i will select a bucket of 60 minutes (lets say) & assign it to any partition OR DN. then after using 60 minutes in all the DN will not able to place any calls.
Its like prepaid billing. IS Cisco CUCM is carrier class PBX, or it is intended only for enterprises???
I got question regarding the same issue and I replied there no way
but if there is any way to do this i will be happy
You you are interested in custom script developed for the purpose, you can contact me at the address present in my profile.
yes,i already sent email to ur profile email id
Without revealing trade secrets/code details I'd be interested to hear a high-level description of the solution, if possible.
Admin sets parameters like who can call where and for how long using which line.
But is not released yet, because nobody so far has put his money where the mouth is.
