08-22-2010 02:44 AM - edited 03-16-2019 12:24 AM
Hi I have 7965G with SIP and I want to convert to SCCP.
I have search a lot of information but I found only guide for 7960/7940
Is the method from 7960 also work with 7965? If the answer is yes please tell me how to
because I can't find a file name "OS79XX.TXT" or SCCP image "P003-08-200.bin" for 7965G
Or can I use file from 7960?
Solved! Go to Solution.
08-22-2010 08:36 PM
convert a 7965 to SCCP using CallManafer is quite easy.
1- Using the phone mac address, define the 7965 in the callmanager, as a SCCP phone.
2- on the phone set the TFTP server to point to the callmanager
3- Reset the phone (unplug/plug)
4- Phone will connect the callmanager and will start to download the SCCP firmware.
Sometimes, if the process does not work, I also do a erase in the phone configuration.
08-22-2010 05:09 AM
Do you have the firmware files already ?
08-22-2010 05:51 AM
I have downloaded "cmterm-7945_7965-sccp.9-0-3.zip" , "cmterm-7945_7965-sip.9-0-3.zip" already
but inside contain
apps45.9-0-3TH1-22.sbn
cnu45.9-0-3TH1-22.sbn
cvm45sccp.9-0-3TH1-22.sbn , cvm45sip.9-0-3TH1-22.sbn
dsp45.9-0-3TH1-22.sbn
jar45sccp.9-0-3TH1-22.sbn
SCCP45.9-0-3S.loads , SIP45.9-0-3S.loads
term45.default.loads
term65.default.loads
which file should I use?
08-22-2010 07:31 AM
Are you using CM, CME, or none of the above ?
08-22-2010 06:05 PM
I use cme version 7.1 (IOS c2800nm-ipvoice-mz.124-24.T3.bin)
but if cm is easier it's ok. I can use it too.(cm7.1)
08-22-2010 08:36 PM
08-22-2010 08:50 PM
Thank you. It works!
