Bandwith utilasation on dual band AP's
Aug 22nd, 2010
If a single band AP with 2,4 GHz radio and N-standard wireless can utilize approx 300 Mbps, does that mean that I can utilize approx 600 Mbps on a dual band AP with N-standard ? Or is there any limitations in the hardware, making maksimum throughput from both radiomodules simultanously to ethernet less than 600 Mbps ?
Leo Laohoo Sun, 08/22/2010 - 15:21
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Nope.  You can only go UP TO 300 Mbps HALF-duplex.
I'm not sure if you are aware that WiFi is like a hub:  One talks and everyone else listens.  It's is the design.
Kjetil Fleten Sun, 08/22/2010 - 15:58
Those 300 Mbps half duplex must be pr. radio-module, right ? If not, why should anyone want a dual band AP ?
I know that wireless is like a hub, but two radio-modules should act like two separate hubs. The question is if we can imagine those two "hubs" interconnected by an internal "switch" so that our througput to ethernet would be 600 Mbps half duplex ?
How should we understand "Option 3" on page 2 of this:
http://www.cisco.com/en/US/prod/collateral/wireless/ps5678/ps6521/product_at_a_glance0900aecd805df476.pdf ?
Leo Laohoo Mon, 08/23/2010 - 15:39
  • Hall of Fame,
    2017 LAN, Wireless
Don't know how they got Option 3 sooooooooooooooo wrong.
