ASA and Group URL
Answered Question
Aug 22nd, 2010
So I have the need to provide two different SSL VPN environments for two different customers on the same ASA 5510 appliance.  Can I create two Group policies, each with a unique group url specified and then assign a ssl cert matching the group url?  From an IP perspective, they would both be hitting the same outside IP address.
Ex:
Group_policy: customerA
     Group URL: https://remote.customera.com
     ssl cert: remote.customera.com
Group_policy: customerB
     Group URL: https://remote.customerb.com
     ssl cert: remote.customerb.com
thanks!
-Craig
Correct Answer by Atri Basu about 6 years 10 months ago
Hey Craig,
Regarding your request let me break it up into 2 parts:
1. Can you use 2 seperate urls on the same ASA for two separate connection profiles
2. Can you use 2 seperate certificates to validate the two urls
Regarding your first query, yes this can be done. You will have to create 2 separate group-policies and  2 conenction profiles aka Tunnel groups. Under each tunnel group define a separate group-url and assign the corresponding group-policy. Your configuration might look something like this:
ASA(config)# group-policy customerA internal
ASA(config)# group-policy customerA attributes
(configure the respective attribute)
ASA(config)# Tunnel-group customerA type remote-access
ASA(config)# Tunnel-group customerA general-attributes
ASA(config-tunnel-general)# default-group-policy customerA
ASA(config)# tunnel-group customerA webvpn-attributes
ASA(config-tunnel-webvpn)# group-url https://ASA1/remote.customera.com
Repeat the above steps and replace "customerA" with "customerB"
Regarding your second question, you can only configure one trustpoint to be used with one interface. So you need to do either one of the following:
1. get a UCC( Unified Client Certificate) for your ASA:
Obtain One UCC with multiple CNs/SANs (Subject Alternative Name extensions) for each ASA FQDN/IP. So you need a UCC certificate with the CN for master FQDN or IP, and SANs for each ASA: ASA-1 FQDN or IP, ASA-2 FQDN FQDN or IP, and so on. Several PKI/Certificate vendors support UCC:godaddy.com, entrust.com, verisign,etc.
Note: the ASA cannot generate a Certificate Signing Request (CSR) with multiple SANS (CSCso70867 is the enhancement asking for this capability ), so you have to have the PKI vendor submit the enrollment for you.
On ASA configure one trustpoint '' and Install/Import the UCC certifcate in this trustpoint. Bind this trustpoint to the outside interface.
2. OR get a wildcard certificate. Wilcard certificates are discouraged in favor of UUC certs. According to one vendor, Entrust,  these are 2 main reasons:
  1. UCC is more secure than wildcard certificates since Entrust UC Certificates specify exactly which hosts and domains are to be protected
  2. UCC is more flexible than wildcard certificates since Entrust UC Certificates aren't limited to a single domain
Hope this helps.
Atri
Overall Rating: 5 (2 ratings)
Correct Answer
Atri Basu Sun, 08/22/2010 - 07:36
  • Cisco Employee,
Hey Craig,
Hope this helps.
Atri
cdickerson Sun, 08/22/2010 - 12:54
Thanks for the great detailed answer. I understand everything but get confused on the group-url command.  In your example you had group-url https://ASA1/remote.customera.com, I don't understand the ASA1 portion of the url.  Same goes for the SAN portion of the UCC cert.  Wouldn't the SAN's be remote.customera.com and remote.customerb.com?  I only have one ASA.  So the ASA1 and ASA2 stuff I am not understanding.
Thanks again
-Craig
Atri Basu Tue, 08/24/2010 - 11:41
  • Cisco Employee,
Hey Craig,
When I normally create different urls I normally create a portion of it that is the same, e.g
for tunnel group 1 i would create group-url https://asa/tg1
and for tunnel group 2 I would create group-url https://asa/tg2.
This way if you want to use the wildcard certifcate then https://asa/* would be what you would use as the CN. However this is not at all necessary. You can use a UCC with multiple SANs.
In your case you are right you can use "https://remote.customera.com" and https://remote.customerb.com.
Sorry for the confusion.
Atri.
