Cisco1701 with VWIC-1MFT-G.703
Answered Question
Aug 22nd, 2010
Hi Friends. I have a Cisco1701 Router and I need to install a VWIC-1MFT-G.703 Card in replacement of BRI Card where's WIC-1ADSL will remain in its place. I am trying with diferent IOS but still couldn't. In fact i have to get an ADSL Connection and G.703 E1 Link both on same router.
Can any one help?
Correct Answer by Nagaraja Thanthry about 6 years 7 months ago
It seems like 1701 does not support Multiflex VWIC cards.
http://www.cisco.com/en/US/products/hw/routers/ps221/products_data_sheet...
6a0080088715.html
You might have to go to slightly higher platform (At least 1721 which is
modular) to pick and choose the cards on the router.
https://www.cisco.com/en/US/products/hw/routers/ps221/products_data_shee...
86a00800920ec.html
Hope this helps.
NT
Overall Rating: 5 (1 ratings)
Correct Answer
Nagaraja Thanthry Sun, 08/22/2010 - 08:18
  • Cisco Employee,
6a0080088715.html
86a00800920ec.html
Hope this helps.
NT
Paolo Bevilacqua Sun, 08/22/2010 - 10:50
  • Hall of Fame,
    Founding Member
You need a minimum of a 1841 to have E1 and ADSL in the same router.
tsolution Sun, 08/22/2010 - 13:17
Thank You NT
Just one more thing i need to ask that if Cisco1721 with 64D/16F 12.4 IOS can support both VWIC-1MFT-G.703 & WIC-1DSL at the same time?
Nagaraja Thanthry Sun, 08/22/2010 - 13:28
  • Cisco Employee,
Seems like both cards are supported in 1721.
http://www.cisco.com/en/US/prod/collateral/routers/ps221/product_data_sh...
900aecd8028aa5a_ps5854_Products_Data_Sheet.html
http://www.cisco.com/en/US/products/hw/routers/ps274/products_tech_note0...
a00800b6e0f.shtml
http://www.cisco.com/en/US/docs/routers/access/interfaces/ic/hardware/in...
lation/guide/oview_ic.html#wp1129978
Make sure that you are running an ADSL image to support the WIC-1DSL card.
http://www.cisco.com/en/US/products/hw/routers/ps214/products_tech_note0...
a00800ae37f.shtml
NT
Paolo Bevilacqua Sun, 08/22/2010 - 14:12
  • Hall of Fame,
    Founding Member
Do not use such an old router.
You will have nothing but trouble.
