VS-S720-10G-3C issue bundling 10G ports
int po1
sw
sw trunk encap dot1q
sw mode trunk
int te5/4
sw
sw mode trunk
channel-group 1 mode desi
int te5/5
sw
sw mode trunk
1     Po1(SD)        PAgP      Te5/4(I)  Te5/5(I)
6509E
VS-S720-10G-3C
12.2(33) SXH7
I tried Pagp, Lacp and the only thing I didnt try was "mode on".  I am not attempting VSS but I was only attempting to create a simple portchannel trunk between the distribution pair.  The portchannel didnt want to bundle with no matter what I did on the config and I am perplexed what I am forgetting or do not know.  Please help.
Reza Sharifi Sun, 08/22/2010 - 12:29
According to Cisco 6500 business unit you can not create Portchanned on the 10Gig port on Sup-720-VS.  Now, I have it configured with no problem working with PAGP which was a surprise to 6500 business unit people but I am running 12.2(33)SXI not SXH.  I would recommend an upgrade to SXI and try again.  It should work.
BTW, The latest SXI release is 12.2(33)SXI4a
Reza
