Cisco 6500 series switch IOS upgrade
Aug 22nd, 2010
Can anyone discuss or forward the procedure for upgrading the IOS for Cisco 6500 series switch.
KARUPPUCHAMY MA... Sun, 08/22/2010 - 21:21
What is the current OS running on your 65K that CatOS or IOS ??
Can you paste the output of the below command from your 65K switch
#sh version
Based on the output sh version, i can suggest the procedure to upgrade the IOS
lmanavalan Sun, 08/22/2010 - 21:35
please below is the sh ver result
Cisco IOS Software, s3223_rp Software (s3223_rp-ADVENTERPRISEK9_WAN-M), Version 12.2(33)SXI1, RELEASE SOFTWARE (fc3)
Technical Support:
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Fri 27-Mar-09 11:40 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)SX3, RELEASE SOFTWARE (fc1)
Swich uptime is 1 year, 5 weeks, 3 days, 4 hours, 30 minutes
Uptime for this control processor is 1 year, 5 weeks, 3 days, 3 hours, 55 minutes
Time since Swich switched to active is 1 year, 5 weeks, 3 days, 3 hours, 52 minutes
System returned to ROM by power on at 21:05:33 UTC Wed Jul 15 2009 (SP by power on)
System restarted at 00:39:45 UTC Thu Jul 16 2009
System image file is "sup-bootdisk:s3223-adventerprisek9_wan-mz.122-33.SXI1.bin"
Last reload reason: Unknown reason
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco WS-C6509-V-E (R7000) processor (revision 1.0) with 458752K/65536K bytes of memory.
Processor board ID ----------
R7000 CPU at 300Mhz, Implementation 0x27, Rev 3.3, 256KB L2, 1024KB L3 Cache
Last reset from power-on
6 Virtual Ethernet interfaces
210 Gigabit Ethernet interfaces
1915K bytes of non-volatile configuration memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Leo Laohoo Sun, 08/22/2010 - 21:50
1.  Copy the IOS into the sup-bootflash:.  You can either use a TFTP server or copy the IOS from your PC to a CF and from the CF to the sup-bootflash:.
2.  Change the boot variable parameter.
3.  Save the config and reload.
lmanavalan Wed, 09/08/2010 - 19:41
Thanks for the help everything went on well.
What is the prcedure to upgrade the code if it is a CatOS           software
Is the process different
