Issue with VPN/IPSEC/Gre/Life
J W
Hello. I am wondering if anyone can be of any assistance. I am trying to set up point to point tunnels, but they are not coming up entirely. I am wondering if anyone notices anything obvious that I am missing. Any assistance would be GREATLY appreciated.
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service compress-config
hostname DataCenter-3825
boot-start-marker
boot-end-marker
! card type command needed for slot/vwic-slot 0/0
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 64000 notifications
logging rate-limit 10 except critical
no aaa new-model
clock timezone EST -5
clock summer-time EDT recurring
no ip source-route
ip cef
no ip bootp server
no ip domain lookup
ip domain name kljhlh.local
vlan ifdescr detail
voice-card 0
no dspfarm
crypto pki trustpoint TP-self-signed-330666185
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-330666185
revocation-check none
rsakeypair TP-self-signed-330666185
crypto pki certificate chain TP-self-signed-330666185
certificate self-signed 01 nvram:IOS-Self-Sig#1.cer
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp key abcdefg123 address <OUTSIDE IP OF PEER>
crypto isakmp invalid-spi-recovery
crypto ipsec transform-set TUN-3DES-SHA esp-3des esp-sha-hmac
crypto map RMTIPSEC 100 ipsec-isakmp
  set peer <OUTSIDE IP OF PEER>
set security-association lifetime seconds 28800
set transform-set TUN-3DES-SHA
match address GRE2peer
no spanning-tree vlan 3
no spanning-tree vlan 4
no spanning-tree vlan 5
no spanning-tree vlan 6
no spanning-tree vlan 150
archive
log config
  hidekeys
ip tcp selective-ack
ip tcp path-mtu-discovery
ip ssh time-out 60
ip ssh authentication-retries 2
bridge irb
interface Loopback100
ip address 10.254.1.1 255.255.255.255
no ip redirects
no ip proxy-arp
ip route-cache flow
interface Tunnel33
description Tunnel to 847 Market/Akron Elem.
bandwidth 2048
ip address 10.254.253.29 255.255.255.252
no ip redirects
no ip proxy-arp
ip mtu 1338
ip hello-interval eigrp 10000 20
ip hold-time eigrp 10000 60
ip route-cache flow
ip tcp adjust-mss 1200
cdp enable
tunnel source Vlan2
tunnel destination <OUTSIDE IP OF PEER>
interface Null0
no ip unreachables
interface GigabitEthernet0/0
description ** Data Center Network Interface **
ip address 10.0.0.1 255.255.0.0
no ip redirects
no ip proxy-arp
duplex full
speed 100
media-type rj45
interface GigabitEthernet0/1
no ip address
no ip redirects
no ip proxy-arp
duplex auto
speed auto
media-type rj45
interface GigabitEthernet1/0
ip address 192.168.50.1 255.255.255.0
interface FastEthernet2/15
switchport access vlan 2
no cdp enable
interface Vlan1
no ip address
interface Vlan2
ip address 10.33.0.11 255.255.255.0
no ip proxy-arp
ip nat outside
ip virtual-reassembly
ip route-cache flow
no mop enabled
crypto map RMTIPSEC
crypto ipsec df-bit clear
interface Vlan102
no ip address
shutdown
interface Vlan118
no ip address
shutdown
router eigrp 10000
passive-interface Vlan2
passive-interface Vlan3
passive-interface Vlan4
passive-interface Vlan5
passive-interface Vlan6
network 10.0.0.0
network 192.168.50.0
no auto-summary
ip route 0.0.0.0 0.0.0.0 10.0.0.2
ip route <OUTSIDE IP OF PEER> 255.255.255.0 10.33.0.1
ip http server
ip http secure-server
ip http max-connections 2
ip nat inside source list LIST1 interface Vlan2 overload
ip access-list extended GRE2847MARKET
permit gre host 10.33.0.11 host 24.123.34.11
ip access-list extended LIST1
permit tcp 10.1.38.0 0.0.0.255 gt 1024 any eq smtp
permit tcp 10.1.38.0 0.0.0.255 gt 1023 any eq pop3
Show crypto sessions yields:
Interface: Vlan2
Session status: DOWN
Peer: 24.123.34.11 port 500
  IPSEC FLOW: permit 47 host 10.33.0.11 host <OUTSIDE IP OF PEER>
        Active SAs: 0, origin: crypto map
Interface: Vlan2
Session status: UP-IDLE
Peer: <OUTSIDE IP OF PEER> port 4500
  IKE SA: local 10.33.0.11/4500 remote 24.123.34.11/4500 Active
  IKE SA: local 10.33.0.11/4500 remote 24.123.34.11/4500 Inactive
And on the opposite end of the tunnel:
interface Tunnel0
bandwidth 2048
ip address 10.254.253.30 255.255.255.252
no ip redirects
no ip proxy-arp
ip mtu 1338
ip route-cache flow
cdp enable
tunnel source FastEthernet0/0
tunnel destination <OUTSIDE IP OF DESTINATION>
end
Thank you for any help!
J W
Also, I ensured the Crypto isakmp key is the same on both sides..
hey wesley,
could you please provide us more information likewhat is the crypto acl, what is the nat acl
if possible please paste the entire config (u can mask the pub ip's)
also please mention in which phase this is failing
you can give the command
show crypto isa sa
the general idea is as follows
crypto acl should be exact mirror image
crypto acl will be from tunnel source to tunel destination
peer would be public ip
here is an example config
http://tools.cisco.com/squish/E4A02
if this is a new setup i would first get gre up and then look into crypto
praprama
Please paste the output of "show crypto map". Also, please run "debug crypto isakmp" and paste it. We can see at which phase the tunnel is failing. Also, i see you have "pasive-interface Vlan2" entered in the eigrp process. That might cause problems when the tunnel finally comes up as no neighborship will be formed on with any device on Vlan2 interface. Try disbaling that as well to see if it makes any difference.
Prapanch
