Call Manager Clusters.(2 Cluseters of Call Manager Servers).
Answered Question
Aug 23rd, 2010
Hi everybody
I have a scenario where i have two cluster.
Cluster # 1 . 2 CUCM's : 1 Publisher and 2nd is  Subscriber. Subnet:10.4.6.0 /24
Cluster # 2.  2 CUCM's : 1 Publisher and 2nd is Subscriber.  Subnet 10.4.7.0 /24
Both clusters are connected to the same Switch. I want to enable call between both the servers using 4 digit ext's.
Both ther server users can talk each other using 4 digits mean ip phones connected to the Cluster 1 serveres can call to the ip phones connected to the second Cluster server.
Waiting for a favourable reply.
Jamil Hussain
Correct Answer by Jaime Valencia about 6 years 9 months ago
Just to add something, if you have overlapping dial plans then just 4 digit dialing won't be possible and you'll need to add another digit as site-code for this.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
Correct Answer by UCcomp2007 about 6 years 9 months ago
Hi Jamil,
You can use inter-cluster trunks (gatekeeper or non-gatekeepr controlled) or you can use SIP trunks between the clusters.  Below is a link to setup doc for inter-cluster trunks (non-gatekeeper controlled).
faculty.valenciacc.edu/wyousif/VoIP/Labs/Inter-Cluster.doc
Overall Rating: 5 (2 ratings)
Correct Answer
UCcomp2007 Mon, 08/23/2010 - 01:34
Hi Jamil,
Correct Answer
Jaime Valencia Mon, 08/23/2010 - 06:44
  • Cisco Employee,
  • Hall of Fame,
    2011
java
