How can I configure a virtual operator with Cisco Unity ver. 7.0.2.10000-38?
Aug 23rd, 2010
I need to configure a virtual operator to redirect incoming calls to different departments when user press different buttons in phone.
Thanks.
Jaime Valencia Mon, 08/23/2010 - 06:47
  • Cisco Employee,
  • Hall of Fame,
    2011
There are plenty of posts on how to configure a simple AA, next time please try searching the CSC before asking.
CTI RP with CFA to VM in CUCM
Create matching call handler for the above DN.
Record your greeting
Create 1 call handler for each option you need to transfer to.
Set the transfer options to "yes, ring subscriber at this extension" and whatever DN you need.
Then in the main CH under caller input set each option accordingly using the "attempt transfer option"
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
