Adding FWSM 4.2 into MARS
talha_490
I have FWSM Module 4.2 on my core swicth. I have purchased MARS. when i add the module into my 6509 it shows FWSM 3.2 maximum. How can i add my FWSM which is running the latest release.
2 Accepted Solutions
Jennifer Halim
The latest version of MARS only support up to FWSM version 3.2.5 as per the following compatibility table:
http://www.cisco.com/en/US/docs/security/security_management/cs-mars/6.0/compatibility/local_controller/dtlc60x.html#wp75149
However, you can add the FWSM as 3.2 version, and it will be backward compatible. Only new syslog messages on FWSM version 4.2 will not be understood by the MARS.
I'm going to assume you meant version 4.1(2).
Anyway, is there a list of the syslog message types that have been added since 4.0?  I don't see any mention of it in the 4.1(2) release notes.
Jennifer Halim
Yes it is 4.1(2)
Muhammad Talha Iqbal Ghouri
Information System Security Architect
GBM - General Marketing and Services Representative for IBM WTC
P.O. Box 819, Manama, Bahrain
T: +973-17584329 Fax: +973-17584334
Mob: +973-39788659 email: ghouri@bh.gbm.ihost.com
http://www.gbm4ibm.com
mikecrowe4ICS_2
I don't know if anyone else sees this issue, but if the device is  part of any automated (re)discovery, it will get reset to version 3.1.   2-3 times in the last couple of weeks, I've manually set my FWSMs to  version 3.2, only to have it as 3.1 a few days later.
In the end, it doesn't really matter.  But it is supremely frustrating.
