Error message while deleting the pcm.dat file from cisco 2811 router
Answered Question
Aug 23rd, 2010
Hi all,
When I tried to delete the file from cisco 2811 router. It shows the following error messages.
%Error deleting flash:/pcm.dat (File in use in an incompatible mode)
Tell me how I delete the file from router.
Ali Raza
Correct Answer by vragotha about 6 years 8 months ago
Try disabling the captures and then delete the pcm.dat file
It should be something like -
no voice hpi capture
no voice hpi capture destination flash:pcm.dat
Overall Rating: 4.5 (2 ratings)
paolo bevilacqua Mon, 08/23/2010 - 05:23
  • Hall of Fame,
    Founding Member
Extact flash (nothing bad will happne), inser in PC, delete file, put back in router.
waqas0612147 Tue, 08/24/2010 - 00:42
Is there any solution for this? Because the router is working in live enviornment and it is very difficult to take a down time for this.
LHR-LDA-JT-DC-RTR#delete flas
LHR-LDA-JT-DC-RTR#delete flash:pcm.dat
Delete filename [pcm.dat]?
Delete flash:/pcm.dat? [confirm]
LHR-LDA-JT-DC-RTR#
Ali Raza
paolo bevilacqua Tue, 08/24/2010 - 02:03
  • Hall of Fame,
    Founding Member
Solution given above, 0 down time.
waqas0612147 Fri, 08/27/2010 - 00:22
How could we remove the flash when server in running condition. I also don't have a slot in PC to insert a flash. Please tell some other suggestion to resolve this issue.
Ali Raza
paolo bevilacqua Fri, 08/27/2010 - 12:42
  • Hall of Fame,
    Founding Member
Again for the hird time, you can remove the flash with the router running without any problem.
Then you get a $10 usb card reader to delete the file.
Correct Answer
vragotha Fri, 08/27/2010 - 23:11
  • Silver, 250 points or more
waqas0612147 Sun, 08/29/2010 - 22:08
Hi Vijay,
Thanks....In first command I just add buffer in last..
no voice hpi capture buffer
Ali Raza
