Replacing a static WEP encryption.
andrea.meconi
Level 2
Level 2
Hello. I need to replace a static WEP encryption between two bridge with a more secure solution.
I'm working with a point to point connection using Aironet 1310 with 12.3.
Many thanks for help.
Andrea
dancampb
Level 7
Level 7
Why not use WPA PSK with TKIP or depending on the 12.3 version you are running maybe WPA2-PSK/AES
I'm applying a WPA-PSK configuration.
Please, where can I find a WPA2 example?
Anyway, bridges are running 12.3(8)JEA and 12.3(11)JA1.
Regards.
Andrea
Here you go:
dot11 ssid testwlan
   authentication open
   authentication key-management wpa version 2
   infrastructure-ssid
   wpa-psk ascii 7 0822455D0A16061E010803
interface Dot11Radio0
encryption mode ciphers aes-ccm
Many thanks for your help.
Andrea
