Cisco 9971 Video Phone displays the FAC code in text format
Aug 23rd, 2010
Running UCM 7.1.5 and new Cisco 9971 Video IP Phones are deployed.
FAC are enabled for outgoing calls. If the user making outgoing call from 9971 IP Phone,the FAC which user enters for making outgoing call is visible in text format on the display of 9971 IP Phone( It suppose to display ******).
Help me out !!!  (Not to display the FAC code visible in text format on 9971 IP Phone).
Thanks & Regards,
Krishnamurthy
paolo bevilacqua Mon, 08/23/2010 - 05:18
  • Hall of Fame,
    Founding Member
Check very latest CM and phone software are installed.
If they are, complain to TAC and do not accept bogus "new feature needed" answers. They may say that because it is a SIP phone and works differently from SCCP.
It would be time enough for Cisco to learn what user needs are before releasing products.
Rob Huffman Mon, 08/23/2010 - 06:03
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Krishnamurthy,
Paolo is most correct here
CSCsb68946            Bug Details
SIP phone needs to replace digits with "*" in FAC
Symptom:
Currently, TNP phones (tested on 7970) will not block out the digits dialed for a FAC code.
Conditions:
Dialing a translation pattern with "Forced Authorization Code" from the phone will result in code digits being display on the phone while typed.
Workaround:
None.
Further Problem Description:
StatusStatus
Open
Severity Severity
6 - enhancement
Last Modified Last Modified
In Last Year
Product Product
Cisco Unified IP Phone 7900 Series
Technology Technology
1st Found-In 1st Found-in
8.0(0.8)
Related Bug Information
SIP TNP phone displays the fac code when a call is made.
Symptom:SIP TNP phone displays the fac code when a call is made.  Condition:SIP TNP phone displays the fac code when a call is made.  Workaround:None
Cheers!
Rob
paolo bevilacqua Mon, 08/23/2010 - 06:31
  • Hall of Fame,
    Founding Member
Severy 6 - enhancement
meaning - will never be fixed unless a multi-million dollar account cries really loud to VP level.
