How to allow WPA1 and WPA2 on same SSID?
Hi everybody,
I am not sure if it is possible but I would like to configure WPA1 and WPA2 on the same SSID for one of our customer. The router is an 881W.
I attach the config [AP_Config.txt] of the AP to the post.
With this config the customer says that it connect with WPA2 but not WPA1. He would to have both on the same SSID. It is possible?
Best Regards,
Laurent
