Call Manager BE Edition 7.1
Aug 23rd, 2010
Hi Guys,
Just installed my first call manager with some help from a third party but i have a few issue
We have
7965 handsets upgraded and working 100%
7960 handsets upgraded and working 100%
7961 handsets  non upgraded and non working
I have tried a reset  # hold down till lights start flashing
123456789*0#
screen is blank no infomation from 4 handsets
The system has the latest language pack , device pack and UK dail plan installed
Also trying to reset an ata 186
The following procedure will reset the ATA to its default config:
a) Take the phone off hook.
b) The red button on the top of the ATA-186 will illuminate.
c) Press the illuminating red button on the ATA and dial 322873738#. (The numbers spell FACTRESET# on the telephone)
d) Voice prompt will ask you to dial * to save changes you have just made.
e) Press * on your phone's keypad.
f) Hang up the phone.
Step C says invalid Number
Overall Rating: 5 (1 ratings)
Rob Huffman Mon, 08/23/2010 - 06:31
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi John,
It's most likely that your 7961 phones are running an older firmware
and your new CUCM-BE build is trying to install 8.5(3) or newer firmware.
The issue turns out to be that the phone firmware needs to be @ 8.5.2 before trying to go to 8.5.3
or later
Download an older Firmware and change your Device defaults for the 7961 to reflect
this "older" Firmware.
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/firmware/8_5_3/english/release/notes/7900_853.html
Hope this helps!
Rob
Felipe Garrido Mon, 08/23/2010 - 08:19
  • Cisco Employee,
John,
What firmware version and protocol are the ATAs currently on? The procedure may only be valid for a specific version and/or protocol. The method detailed in your post will only work for version 2.x and higher. The below link details the procedure for older firmware versions.
http://www.ciscotaccc.com/kaidara-advisor/voice/showcase?case=K29727621
-Felipe
