C6500 VSS, ACE and RHI
Aug 23rd, 2010
I am planning VSS installation with one ACE and FWSM per physical chassis. As FWSM is "behind" the ACE I have
no problem using RHI, but I was wondering is RHI supported in VSS scenario or not?
Pavel Dimow Mon, 08/23/2010 - 10:12
Hello Reza,
thank you for your reply, but I must admit that I am a little bit confused (this is because I don't have hands on experience with ACE and RHI), but I am wondering, why should I care if FWSM does not support RHI, as in my case ACE would have a "direct connection" to MSFC, so FWSM is behind ACE, and is not problem for RHI to work, or I am terribly wrong?
Jeremy Buck Mon, 08/23/2010 - 14:34
Pavel,
Are you running the FWSM in transparent mode or a routed mode?
Jeremy
