08-23-2010 06:41 AM - edited 03-06-2019 12:36 PM
I'd like to know one thing about 4500 switches. Why are part numbers for main and redundant supervisors different? I mean, why two different PNs exist: ws-x4516 and ws-x4516/2? Is it a means of tracking something or the modules are indeed different?
What if I have a 4507R and two ws-x4516 and no ws-x4516/2? Can I build a redundant system and get RPR to work?
BR,
Serge
Solved! Go to Solution.
08-23-2010 01:22 PM
To add to Reza's comments, the existence of the two Part IDs doesn't extend beyond the ordering tools/price lists.
If you order a WS-X4516/2 and insert it in a chassis, the output of show mod will display as WS-X4516.
IIRC, the difference in the part IDs exists for the purposes of pricing bundles, but serves no purpose in terms of system operation.
HTH,
Bobby
08-23-2010 09:33 AM
Hi Serge,
Here are the descriptions. You should be able to build a redundant system. According to the description the second one is your redundant Sup.
So, you should be fine.
WS-X4516 | Catalyst 4500 Supervisor V (2 GE),Console(RJ-45) |
WS-X4516/2 | Catalyst 45xxR Redundant Supervisor V (2 GE),Console(RJ-45) |
Reza
08-23-2010 01:22 PM
HTH,
Bobby
08-24-2010 04:22 AM
Thank you very much Bobby. Now I got it.
They are physically identical. And having different PNs may indeed come in handy when assigning prices for fancy bundles. It makes perfect sence now.
BR,
Serge
