DMVPN GRE tunnel not connecting failed to encapsulate
Answered Question
Aug 23rd, 2010
I am trying to set up GRE tunnel over Verizon HWIC-3G-CDMA card as per Verizons document. Does anybody have backup over EVDO working?
PDF Schematic - attached
Verizons Document -  Attached
The relevent commands are below
interface Tunnel0
ip address
no ip redirects
ip nhrp map multicast dynamic
ip nhrp network-id 100
tunnel source
tunnel mode gre multipoint
interface Serial1/0
description Verizon MPLS VPN T3
ip address
ip flow ingress
encapsulation ppp
dsu bandwidth 44210
interface Tunnel0
description GRE tunnel to the Hub
ip address
no ip redirects
ip nhrp map
ip nhrp nhs
ip nhrp registration no-unique
tunnel source Cellular0/1/0
interface Cellular0/1/0
description ***** VzW EVDO Interface *****
ip address negotiated
encapsulation ppp
dialer in-band
dialer idle-timeout 0
dialer string EVDO
dialer-group 1
async mode interactive
ppp chap password 7 120F1F00
ip route Cellular0/1/0
Correct Answer by Diego Armando C... about 6 years 1 month ago
in the spoke the command  ..ip nhrp nhs    is wrong you have to use the tunnel IP ...ip nhrp nhs
Just in case here is a configuration example.
Overall Rating: 5 (1 ratings)
Related Content
