ASDM 6.3(1) on ASA 5520 8.2(2) is showing empty service-groups...
Aug 23rd, 2010
Hi there,
I just discovered that my ASDM 6.3(1) is ignoring all my "service-object tcp [blabla]", "service-object udp [blabla]" and "service-object tcp-udp [blabla]" from my ASA 5520 v.8.2(2).
That means that some service-groups show up as empty in the ASDM.
I suspect ASA -> ASDM versions to be incompatible. Can anyone confirm my suspicion?
Thanks!
/Thomas Winther
Nagaraja Thanthry Mon, 08/23/2010 - 09:04
  • Cisco Employee,
Do you have "destination" keyword in those service-objects? If yes, it seems
like 6.3 will be incompatible with your configuration/ASA code version. You
can downgrade the ASDM version to 6.2.
Hope this helps.
NT
Thomas Winther Mon, 08/23/2010 - 14:56
No, there is no "destination" keyword in my current config'd service-object.
But I think you might be close... If I add a new servicegroup in the ASDM, and previews the lines before submitting, they actually have "destination" keyword. So maybe ASDM 6.3(1) only accepts service-objects with destination defined..?
//Thomas
Nagaraja Thanthry Mon, 08/23/2010 - 17:23
  • Cisco Employee,
The issue is documented in CSCtf77014. It seems like the ASDM tries to add
the "destination" keyword which is not recognized by the 8.2 code. Please
try downgrading the ASDM to 6.2 and see if that helps.
NT
Related Content
