Wirless Vlans and DHCP
Answered Question
Aug 23rd, 2010
I am trying to configure my Aironet 1121G acess points with several vlans, got the vlans all working fine with wired devices, but the wirless devices don't get DHCP.
Basically, I have the BVI on my managment vlan and two other vlans that pass through, trying to have the public WiFi on 1 vlan and two corporate vlans with seperate wifi. can't get IPs on any of them though.
Vlnas are routed by a catlayst 3550 with helper addresses configured on all the vlan interfaces.
DHCP comes from 2 windows server 2003 boxes on a further vlan
any Ideas?
Correct Answer by vinodjad1234 about 6 years 4 months ago
As i understood , you have connected your AP to your one of the L2 switch. I would suggest you to configure your L3 ( gateway switch ) with dhcp pool to get the ip address for respective vlan first.
To configure dhcp pool in your L3 192.168.2.1 .
create SVI interface and assign IP address for the respective VLAN ( that will act as a gateway the respective vlan )
repeat the same thing for all the vlans.
create the DHCP pool for the respective vlan and give default-router with L3 ip address.
AccessPoint#configure terminal
AccessPoint(config)#interface dot11radio 0
AccessPoint(config-if)#ssid .......give the name of your ssid
AccessPoint(config-if-ssid)#vlan ?
AccessPoint(config-if-ssid)#authentication open
AccessPoint(config-if-ssid)#end
AccessPoint(config) interface fastethernet 0.30
AccessPoint(config-subif) encapsulation dot1Q 30
AccessPoint(config-subif) exit
AccessPoint(config) interface dot11radio 0.30
check whether you are getting the ip address for the clients.
In case you are expecting to get the IP address from your external dhcp server ...........
try to give below command on each respective dot11Radio 0  subinterface  " ip helper-address .... give the dhcp server ip address here "
please let me know whether it is working .........................
thanks,
vinod
Overall Rating: 5 (1 ratings)
vinodjad1234 Mon, 08/23/2010 - 21:55
could you please send configuration which you have done on AP ..... it would help to troubleshoot .
Vinod
Peter Marquis Tue, 08/24/2010 - 02:35
Vinod,
     Here is the AP config, I'm confused, so any help would be useful, got to get a wireless course under my belt.
Cheers,
Peter
version 12.3
no service pad
service password-encryption
hostname IT_AP1121G_01
no logging console
enable secret
ip subnet-zero
aaa new-model
aaa group server radius rad_eap
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
dot11 vlan-name Corporate vlan 3
dot11 vlan-name Default vlan 1
dot11 vlan-name Managment vlan 2
dot11 ssid stosWIFI
vlan 1
authentication open
guest-mode
mbssid guest-mode
infrastructure-ssid optional
mobility network-id 1
dot11 ssid stoswaldsWIFI
vlan 3
authentication open eap eap_methods
mobility network-id 3
username admin privilege 15 secret 5 $1$.dBF$jstGCUjGPaD6OQ/JVmZEY1
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
shutdown
encryption key 1 size 128bit 7 0D1A262E215F252C7E5A2D6A6498 transmit-key
encryption mode wep mandatory
encryption vlan 1 key 1 size 128bit 7 DA303E012047F6068707FC131B4A transmit-key
encryption vlan 1 mode wep mandatory
encryption vlan 3 mode wep mandatory
ssid stosWIFI
ssid stoswaldsWIFI
mbssid
speed basic-1.0 basic-2.0 basic-5.5 basic-6.0 basic-9.0 basic-11.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0
channel 2412
station-role root
world-mode dot11d country GB both
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 254
bridge-group 254 subscriber-loop-control
bridge-group 254 block-unknown-source
no bridge-group 254 source-learning
no bridge-group 254 unicast-flooding
bridge-group 254 spanning-disabled
interface Dot11Radio0.3
no ip route-cache
bridge-group 3
bridge-group 3 subscriber-loop-control
bridge-group 3 block-unknown-source
no bridge-group 3 source-learning
no bridge-group 3 unicast-flooding
bridge-group 3 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
interface FastEthernet0.1
no ip route-cache
bridge-group 254
interface FastEthernet0.3
no ip route-cache
bridge-group 3
bridge-group 3
interface FastEthernet0.2
encapsulation dot1Q 2 native
no ip route-cache
bridge-group 1
no bridge-group 1 source-learning
bridge-group 1 spanning-disabled
interface BVI1
ip address 192.168.2.33 255.255.255.0
no ip route-cache
ip default-gateway 192.168.2.1
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
logging trap notifications
logging
radius-server attribute 32 include-in-access-req format %h
radius-server vsa send accounting
control-plane
bridge 1 route ip
line con 0
password
line vty 0 4
password
line vty 5 15
end
Correct Answer
vinodjad1234 Tue, 08/24/2010 - 03:47
thanks,
vinod
Peter Marquis Wed, 08/25/2010 - 01:17
By preference I would like to run the DHCP on the 3550, but the monitoring tools we have don't give us the statistics we get from server 2003
Ok Tested it all now, it seems the encryption is failing to authenticate. copied the settings from one of the other access points with the single ssid set-up
The non-broadcast ssid is open auth but I still cant connect, this is the importnat bits of the ap config
ip subnet-zero
aaa new-model
dot11 vlan-name Corporate vlan 20
dot11 vlan-name Managment vlan 42
dot11 ssid stosWIFI
   vlan 1
   authentication open
   guest-mode
   mbssid guest-mode
   vlan 20
   authentication open
   mobility network-id 20
dot11 network-map
dot11 arp-cache optional
bridge irb
no ip address
no ip route-cache
shutdown
encryption vlan 1 key 1 size 128bit 7 715E582F760E232942AF331B7D05 transmit-key
ssid stosWIFI
ssid stoswaldsWIFI
channel 2412
station-role root
ip helper-address 192.168.1.26
ip helper-address 192.168.1.30
no ip route-cache
bridge-group 254
interface Dot11Radio0.20
encapsulation dot1Q 20
ip helper-address 192.168.20.1
no ip route-cache
bridge-group 20
bridge-group 20 subscriber-loop-control
bridge-group 20 block-unknown-source
no bridge-group 20 source-learning
no bridge-group 20 unicast-flooding
bridge-group 20 spanning-disabled
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
no ip route-cache
bridge-group 254
interface FastEthernet0.20
no ip route-cache
bridge-group 20
interface FastEthernet0.42
encapsulation dot1Q 42 native
no ip route-cache
bridge-group 1
Message was edited by: Peter Marquis
Related Content
