IP Phones 7912 - CM 7.1.5
Aug 23rd, 2010
Hello.
I had installed the CM 7.1.3 and now i upgraded it to 7.1.5. When i apply the softkey configuration to 7912 ip phones, i can not see the AbbrDial Softkey.
I loaded the last  firmware version for that type of phone on the CUCM but it not work.
Thanks for you help
Best regards
Jose Luis Arango Carvajal
Jaime Valencia Mon, 08/23/2010 - 09:40
  • Cisco Employee,
  • Hall of Fame,
    2011
You do not add that softkey to the softkey template, it's already there.
While on-hook dial 1 digit and you should see it appear.
If you mean for off-hook follow these instructions.
Off-Hook Abbreviated Dial
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucm/rel_notes/7_1_2/cucm-rel_notes-712.html
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
Jose Arango Mon, 08/23/2010 - 09:56
Yeah you are right it is in offhook but the Abbr Softkey does not appear, it´s the same for 7911 ip phones.
