Ethernet over DS3
Aug 23rd, 2010
can we extend our etheret (vlans) over DS3. what are the steps to do it? Do we need some configurations on cisco devices or it is handled by converters(ethernet to ds3 converter)?
thanks in advance.
Giuseppe Larosa Mon, 08/23/2010 - 11:10
  • Hall of Fame,
    Founding Member
Hello Aaron,
either you implement a L2 transport service over IP or MPLS using L2TPv3 or Ethernet over MPLS on Cisco routers or you rely on a WAN provider that will give you an Ethernet over SDH service that may be terminated on ethernet interface both ends.
for L2TPv3 see
http://www.cisco.com/en/US/docs/ios/12_3t/12_3t2/feature/guide/gtl2tpv3.html
you will need a pair of cisco 3825 or better to do the job and the appropriate IOS image
with devices supporting MPLS EoMPLS may be a choice but you are likely to need more powerful  boxes (C7200 or better)
Hope to help
Giuseppe
ROBERTO TACCON Mon, 08/23/2010 - 11:41
Hi Giuseppe,
can you post/indicate a working MPLS EoMPLS configuration example/url ?
Roberto Taccon
Giuseppe Larosa Mon, 08/23/2010 - 13:32
  • Hall of Fame,
    Founding Member
Hello Roberto,
I would suggest per Vlan EoMPLS
see
http://www.cisco.com/en/US/docs/ios/mpls/configuration/guide/mp_any_transport_ps6441_TSD_Products_Configuration_Guide_Chapter.html#wp1047047
However, depending on your hardware and IOS version there can be many variants specially for C6500/C7600 where having SIP linecards or ES or ES+ linecards can make great difference.
Also on C6500/C7600 in some cases you could use EoMPLS on the SVI ( I have never used it)
One important point is that standard feature requires same vlan-id at both ends, some platforms support vlan-id rewrite see in the same link.
Also EoMPLS  with targeted LDP ( draft Martini) is a point to point service.
On Cisco 12000 you can mix L3 subinterfaces, MPLS core subinterfaces and EoMPLS access subinterfaces on the same port (3GE engine 2 or better).
Hope to help
Giuseppe
